RCU Forums - View Single Post - Dynaflite SE5A / S.E. 5A / SE-5 / SE-5A / Build
Old 02-13-2006 | 10:56 PM
  #121
Mode One
Default RE: Dynaflite SE5A / S.E. 5A / SE-5 / SE-5A / Build
"Do four ailerons work better then the four ?.. Better enough to run the likage from the bottom one to the top one ?."
What were you trying to say here Iron Cross? Prop, How big (Torque) servos did you use. I like the idea of reducing cost, weight and wiring with using two, also.
