RCU Forums - View Single Post - Cline or Iron Bay?
Old 02-14-2006 | 10:12 AM
rcpattern
My Feedback: (45)
Default RE: Cline or Iron Bay?
We usually recommend trying muffler pressure first. Saves the work. He is right though, sometimes Super Tiger's already have the work done for you. If it has the bolt you can remove and replace with the pressure fitting, then go ahead and do that. If it doesn't, you can run muffler pressure. Our regulators do not require a great deal of pressure to work. You are only using pressure to force the fuel to the back of the regulator. This doesn't require a great deal of pressure. As I said, if its easy, go ahead and install the pressure tap..if its not. Then you can try muffler pressure first.
Arch Stafford
