RE: Black Magic v2 builder's thread! *Updated*
Oh Keith of little faith.
That's what's cool about this little cheapo laser, it's perfectly suitalble for this application. The lines it shoots are perfectly straight, once the photons are emited they have to go straight unless they are refracted or reflected. First you build a straight and square jig on a perfectly flat surface, then align the laser to the jig (that's what the adjusment knobs are for), locate your fuse formers with the vertical target lines in the jig and turn on the laser. When your targets line up with the laser- you're good to go. Simple, fast, accurate and cheap! Go to Radio Shack and check em out.
Believe my brother.
Gene Webber
Director
Caleeefornia Department of Pattern
