ORIGINAL: DarZeelon
The only TT sport engine that still uses a chromium plated sleeve is the .36PRO.
All the others are ABN.
Britbrat,
Have you seen a full size engine's piston that succumbed to fatigue?
I have. It broke clean through the oil ring groove.
The crown actually sepatated from the skirt...
Model engines run at a much higher relative load, compared to auto engines.
There is no speed limit where we fly....
With cars, 90% of the time they are at a 20% load, or less.
Cruising at 60 mph takes about 13-19 HP, of the 100-200 the engine can produce.
So model engine pistons are prone to fail much sooner, from metal fatigue.
Yeah, but if you mounted a dashboard mixture control for the auto engine, how long do you think auto engines would last? <G>
