RCU Forums - View Single Post - TT.46Pro break in
Old 02-14-2006 | 09:09 PM
  #32
downunder's Avatar
downunder
Default RE: TT.46Pro break in
Fatigue is simply not an issue with model engines as far as determining engine life. Wear over very long periods is all that determines it. Take a ringed engine....after hundreds of hours the ring wears out so you fit a new one and then that very same piston continues on for the next couple of hundred hours. Then you fit another ring
