RE: Telemaster bomb door question
Here are the pictures. It's kind of hard to tell because the wing is covered. I sandwiched a piece of heavy ply cut in the shape of a wing rib between the wing halves. I cut large slots in the rib to allow the joiner pieces to slide through so there is no way it's coming apart. If you notice an also got rid of the dihedral by cutting new pieces from spruce and heavy ply. I also reinforced the forward bulkhead with heavy ply and cut a slot for the hold tap to fit. In the rear I used a piece of spruce and reinforced it with triangle pieces on the under side. All of the pieces were glued with 30 min epoxy. I don't think I will have any problems with this set up.
