RCU Forums - View Single Post - ONE QUESTION ONLY BEFORE I EXPLODE
Old 02-14-2006 | 09:56 PM
rhklenke's Avatar
rhklenke
My Feedback: (24)
Default RE: ONE QUESTION ONLY BEFORE I EXPLODE
ORIGINAL: DelGatoGrande
ORIGINAL: rhklenke
Of course what really keeps it from leaking is this:
http://dreamworksrc.com/catalog/prod...roducts_id=465
Bob
sir in that you are whronge as this is my job.im a tecnisian of medical machines
this is only to HOLD your line on the fiting dont pop out from the presure.
the SEALING is done by the cone shape of each niple
Oh, I disagree. If you double wrap the safety wire so that it forms a complete circle around the line which tightens when you twist it, it certainly does increase the pressure between the tubing ang the nipple which will help prevent leaks. It works just like a cable clamp...
In addition, in a lot of installations, there are air lines with tee's or fittings, that wind up near the turbine or tailpipe and these can easily leak when the tubing gets warm and loosens its grip on the nipple - even if it doesn't actually come off the nipple. Safety wiring these will also greatly reduce the occurence of leaks.
Bob
