RCU Forums - View Single Post - Cline or Iron Bay?
Old 02-15-2006 | 08:52 AM
SamD
Default RE: Cline or Iron Bay?
Muffler pressure? Why use the regulator if you're only running muffler pressure to the tank? You can get that without spending the $50+ for the regulator! Pressure isn't what makes the regulator "work"; it's the negative pressure the diaphragm sees from the carb venturi- thus regulating pressurized fuel into the carb- same as the Walbro carbs seen on most gassers.
