RCU Forums - View Single Post - wing area??
Thread: wing area??
Old 02-15-2006 | 09:59 AM
hpergm's Avatar
hpergm
Default RE: wing area??
ORIGINAL: bodywerks
There's more to it than just that. Wing loading is what you are really looking for. Plus, read post #378 in the 50cc Yak thread in the Aerotech support forum (in Giant scale forum). That guy did actual measurements and only got 1330 sq.in. I don't know for sure, but I think the QQ Yak wing area is more accurate.
Now, take the actual weights of what people's planes are coming in at. Again, while Aerotech has and advertised weight of 16.5-17 pounds, most of them are coming in at 17.5-19 pounds, while the QQ's are easily built at 16 pounds or less.
For the sake of truer comparison, lets say you can get an Aerotech down to 17.5 pounds and it actually has 1410 sq.in. Your wing loading is 28.6 ounces. Then take the QQ at 16 pounds and it's 1330 sq.in and you get a 27.7 ounce wingloading. They are relatively the same size, so Reynold's numbers don't matter, and the QQ appears to be the winner, by an ounce in my comparison, but I was being generous to the Aerotech's specs...
In my opinion, the QQ Yak is a FAR superior plane, in both flight and quality. The cheesy fiberglass canopy of the Aerotech is enough to keep me from buying one...
bodywerks, I'm the one who did the measurements on the AT Yak. I haven't updated my measurements on the Yak thread yet but I have since remeasured the wing area a little more carefully on the AT Yak and found it 1371sq.in. If one pulls the wings off the fuz recesses until they touch the exterior skin, then the 1411 sq.in. figure can be arrived at.
Now, if we take the benchmark plane (EF 50cc Yak), it neither is 87" (its 85" ), nor its true wing area is 1450sq.in (this has been posted somewhere on the QQ Yak thread, I don't have the plane at hand). You only get 1450 if you do the same as with the AT Yak (add wings and central fuz area unassebled so you cheat on the area overlap within the wing sockets).
The QQ yak specs post the area without the above trick, so the fair comparison is EF ~1380 TRUE, QQ 1350 TRUE, AT 1370 TRUE. They are pretty close. QQ is the lightest, so this would be the choice. My AT Yak will be close to 17lbs (with a cannister) so I expect good performance. But, take your pick!
As far as the cheesy FG canopy is concerned, I do not find it ugly (quite the contrary)!! Have a look...
