RCU Forums - View Single Post - H9 Extra 260 - pull-pull
Old 02-15-2006 | 10:38 AM
Tor's Avatar
Tor
Default H9 Extra 260 - pull-pull
If I remember correctly from the 90+ page thread, there was a problem using the supplied pull-pull system. How do you solve this?
Also what servo arm to use for the ruddder servo using pull-pull (Hitec servo). Since the wires should be crossed, I suppose it ought to be an offset arm to keep the wire tension on the non-pulling wire?
