RE: Cline or Iron Bay?
With the Iron Bay Regulator, it doesn't take much pressure to make it work. All you are doing is forcing fuel to the back of the regulator. That doesn't require a great deal of pressure. Usually muffler pressure with the check valve is more than enough. In cases where it isn't then you can try tapping the crank case.
Arch
