RE: ring installation
To install a ring on the piston, you place the ring on the top of the piston. Gently slide one end of the ring at the ring gap down the side of the piston and into the groove. Carefully work your way around the piston, easing the ring down the side of the piston. We use our thumbs to gently work the ring over the top of the piston and into the groove.
