RE: check this out !! new Bergonzoni 1/8 buggy
The fuel tank hanging over the drive shaft only raises the center of gravity, all of the turn buckles are thin, the single wing post will probably break after a few hits, the front suspension arms are very long which will let them break easier, that bulg will do absolutly nothing for air flow because it shrinks back to normal size at the carb mouth anyway, and if it has all of this wrong with it who knows what else there can be. It doesn't look bad but you can deffinatly buy better.
