RE: Position of Mounting a Gyro
a gyro is there to offset the yaw or hold the tail from spinning as you wind up the engine (main rotor)therefore it has to control the servo that adjusts the pitch on the tail rotor, if you have a fixed pitch on the tail rotor the it would control spend of the motor .
I think this answers your question??it is a little confusing.
