futaba fp t5nlh conquest
i'm starting with helies and i'm not sure if this transmitor-futaba fp t5nlh conquest-will do the job.
i'v got a problem with the idle up function.
when i turn on the idle up, the peach rang doesn't change. the only thing that hapense is that the throttle minimum gets higher.
i found only one function related to the idle up and its setting the throttle minimum. if i lower the throttle stick under the minimum the servo won't respond.
is that normal?
anyone has any axperience with this transmitter?
thanx!
