RCU Forums - View Single Post - Carbon Fiber Pushrods for Split Elevator
Old 12-01-2002 | 05:06 AM
bear750
My Feedback: (30)
Default Carbon Fiber Pushrods for Split Elevator
Dubro makes a "splitter" that is basically a Y-adapter. It has one threaded end at the servo side and two threaded ends at the pushrod side. This way you can run your pushrods full length all the way to the servo. Once you get to the servo, you connect both pushrods to the splitter and then the splitter to the servo arm. Hope this helps.
D
