RCU Forums - View Single Post - SHIFT POINTS/LATER vs. SOONER
Old 02-16-2006 | 06:14 PM
Bria1
Default RE: SHIFT POINTS/LATER vs. SOONER
What I've noticed is if it shifts later, the engine may not be pulling it as hard in the upper rpms. You'll see your truck accellerate good from a stop, flatten out, shift and then start pulling good again. Ideally it should shift just as the peak power of your engine starts to drop off a little.
