RCU Forums - View Single Post - Insight build...another wood roach.
Old 02-16-2006 | 10:15 PM
  #269
flyintexan's Avatar
flyintexan
Default RE: Insight build...another wood roach.
Its been a while but I have been tinkering along....slowly.
The wing panels are now in the hands of the finishing artist.
The fuse still has some detail work to do but I have been filling and sanding a little at a time.
I removed the motor (had to cut out a touch more around it to get it out.
I still have to place it back in and setup the nose ring which is already made.
I finally secured the blind nuts for good (epoxy) on the back of the firewall using spacer/donuts for extra support.
I also found some nylon washers for the landing gear screws...should protect the c.f. gear plate nicely.
ID:	409657   Click image for larger version
ID:	409658   Click image for larger version
