Stabilizer/Wing angle
I am building a four star 60 and after installing the stab and confirming equal distance from wing TE to stab TE on each side of the stab.. as per the instructions. I then glued the stabin place with 5 min. epoxy...Then I glued the fin/rudder in place , aligning it with a square, again..per instruction book. I notice now after the epoxy's good and set..that the angle of the stab in relation to the wing is 2-3 degrees off[:@] Is this a serious problem? I was hoping trim might compensate for this slight difference. What are the thoughts of the experts? If I have to take this off...It's gonna be a real pain in the butt!!
