Todays update.......
Well, I have gotten most of the fuse done now and am moving on to sheeting the last bit of the fuse up front. Lastnight and today I got the elevator stabs epoxyed on and set with - 2*(degress) built in. I also got the Canopy plate built and bolted in with 4-40 bolts and 4-40 blind nuts to hold the canopy in place. I also added a back piece to help glue the canopy down after finishing and will be also adding a floor deck and dash plate aswell...No thought yet as to if I will use a Pilot inside....more then likely it will be a half pilot. and a dash kit from Sig or someone else if I can find what I am looking for......I also got the engine box glued and glassed in lastnight though it took a bit of work and modding to get it to fit the way I wanted. I have NOT glued in the engine box firewall yet as Im still not sure what engine I will be going with ? I will keep everyone posted on witch one I go with but it will be a nice size Gas and nothing less. I should have the fuse done by sometime tonight if not mid day tomorrow, depending on how my date goes...lol
Anyway I also will be changing the way the Elev. servos get bolted in...I think rather then having them inside the fuse I will have then outside and easyer to get to if needed....I am also looking into maybe using mini high tq. servos for this and mounting them inside the Elev. stab its self. I will know if I am going this route in a couple hours after a trip to our local hobby shop......pics to follow....enjoy
