RCU Forums - View Single Post - Propeller to "wide" for Spinner
Old 02-17-2006 | 03:46 PM
MasterAlex's Avatar
MasterAlex
Default RE: Propeller to "wide" for Spinner
ORIGINAL: CRFlyer
This is a common problem. You can shave off some material from your spinner on each side so the prop will fit. However, you will want to try and remove the same amount of material from both sides to keep the spinnner balanced properly.
Now that sounds like a pain! [:'(]
Any advise on how to make this not painful? Besides putting back on the 10x8 ...
Is this a job for the Dremel? How do you guys tackle without making the spinner look like garbage.
Thanks!
-MA
Edit for spelling.
