RCU Forums - View Single Post - Sheeting a wing - step by step, Please!
Old 12-01-2002 | 05:34 AM
David Cutler's Avatar
David Cutler
Default Sheeting a wing - step by step, Please!
It's likely you will only be asked to sheet the leading edge of the wing.
Start by cutting the sheet approximately to size, making sure the leading edge of the sheet is perfectly straight; cutting it with a new blade in your knife, using a long steel straight edge ruler.
Make sure there are no proud points, maybe created by blobs of glue, looking carefully at the junction between the ribs and the leading edge to make sure the sheeting fit along the LE is a good one with no gaps.
Start gluing the edge along behind the leading edge. There are two methods for gluing the leading edge depending on the shape. Either place the sheet along the edge of the LE, carefully dropping thin CA along the joint between the sheet and LE as you work your way along the span of the wing. Or, put a bead of thick CA along the edge of the sheet, place it against the back length of the LE, sticking it there with scotch tape.
Whichever way you use, the sheet will be sticking up at am backward angle from the LE of the wing until the glue dries.
Next, depending on how flexible the sheet is, (you can wet it to help the bend down to the spar), bend the sheet down, and using the long steel rule, cut it to length, probably along the back edge of the spar, or wherever the plans say you should.
Then carefully bend the sheet away from the ribs, and drip thick CA down the edges of the ribs, as far towards the LE as possible, and along the top of the spar. Now bend the sheet down, while pulling it away from the LE, so it lies against the top of each rib, with no gap, and down on the spar. Keep the sheet there by pressing the edge of the long steel rule against the sheet, parallel to the spar, but about 1/8 inch from it. While holding it there, you could wipe away any excess glue from the spar/sheet edge (this makes it easier for any rib cap strips to be added afterwards, as there won't be any glue to hinder their fit).
Hold there until the glue sets enough not to move when you take the steel rule away. Wetting the sheet actually acts as a slight accelerator for CA glue which should help.
Sand, but only using a long sanding block, so that no dips between the ribs are created.
There are many variations to the above, as everybody has their favourite methods, but it should work!
One further point:- Remember that the first time the wing has any stability to it is after the sheeting has been added, so that is the time any warps are either created or removed. Take time making sure the wing is pressed down against the flat building board, and the straight wing you create will be strongly held in that position by the sheeting.
Hope all that helped!
David C.
