RE: Is a HPI Pro-4 good for drifting?
pro 4 is shaft driven and a spool is a solid axel completly different to a differential... a diff will allow the outer wheel to turn faster to the inner wheel where as a spool will make both wheels turn at the same speed under cornering as a very basic way of putting it .... a spool is perfect for drifting in the rear anyway
