RE: Thecheatscalc's 36 tuning and assy
You most definatley need to check the balance and tracking of the blades. I imagine there is lots of information on the forums about it? The center of gravity of each blade has to be the same and then they need to balance also. Once they are balanced then the tracking needs to checked and adusted if required.
I changed out the electronics beacuase of all of the bad info I read about them, also I went brushless and wanted to put it on my new Optic 6 radio. I will use the servos in Slow Stick or such. I hope to fly it in my hanger tonight and I will let you know how it works!
Regards,
Phil
