RCU Forums - View Single Post - JetCat question
Old 02-18-2006 | 02:13 PM
JetflyerJ
Banned
My Feedback: (67)
Default RE: JetCat question
ORIGINAL: mr_matt
Hello,
JetCat USA does not recommend propane for starting gas as the vapor pressure of straight propane is much higher than the butane/propane mix.
In hot weather, the pressure can increase to a point that it will rupture the lines we use. Otherwise the motors start fine on it, but as you can imagine having lines burst in the pits and dumping a whole load of propane into the fuselage is not good.
Hope that helps,
Thank you very much Matt, that answers my question. I guess I'll have to suck it up and keep using Powermax.
Johnny Hernandez
