RE: TMD HELP!
Hi Scott,
Here's some instuctions:
Below is are the necessary bits of a TMD file of a VPP plane,
The red lines mean that you need to change the original line to that.
The blue lines mean that you need to Replace the line in the TMD of the model you are working on with this line (put it in the same place if possible).
The purple arrows point to where you can change the "servo slow".
The green arrows point to where you can change the pitch (IF AFPD CRASHES EXIT AFPD AND MAKE THE PITCH LESS BOTH WAYS IN THE TMD!).
Hope this helps!
Greg.
Here's the copy of the bits you need to change in the TMD file:
__________________________________________________ _______________________________________
// aerofly professional --------------------------------------------------------
// file: xxxxxxxxxxxx.tmd
// version: 1.8.0
// type: 97
// lock: 0
Append tmdjoint00 Joint00
Append tmdjoint00 Joint01
Append tmdjoint00 Joint02
Append tmdjoint00 Joint03
Append tmdjoint00 Joint04
Append tmdjoint00 Joint22
Append tmdjoint00 Joint23
Append tmdjoint00 Joint24
Append tmdreceiver00 Receiver
Append tmdfuselage00 Fuselage
Append tmdwheel00 Leftwheel
Append tmdwheel00 Rightwheel
Append tmdwing00 LeftWing
Append tmdwing00 RightWing
Append tmdwing10 Leftstabilizer
Append tmdwing10 Rightstabilizer
Append tmdwing11 Stabilizer
Append tmdservo00 ServoRudder
Append tmdservo00 ServoElevator
Append tmdservo00 ServoLeftAileron
Append tmdservo00 ServoRightAileron
Append tmdpropeller10 Propeller
Append tmdengine10 Engine
Append tmdservo00 ServoThrottle
Append tmdservo00 ServoPitch
cd Propeller/
X = tmvector4r( 0.0000, 1.0000, 0.0000, 0 )
Y = tmvector4r( 0.0000, 0.0000, 1.0000, 0 )
Z = tmvector4r( 1.0000, 0.0000, 0.0000, 0 )
R = tmvector4r( 0.2399, 0.0063, 0.0064, 1 )
Geometry( "~Geometry/Propeller/" )
Mass = 0.01
RangeMassMax = 0.02
RangeMassMin = 0.005
Inertia = { 0.0004, 0.0000, 0.0000, 0.0000, 0.0000, 0.0004, 0.0000, 0.0000, 0.0000, 0.0000, 0.0004, 0.0000, 0.0000, 0.0000, 0.0000, 1.0000 }
Kn = 4000
Dn = 10
Dv = 5
Radius = 0.114306
RangeRadiusMax = 0.269592
RangeRadiusMin = 0.067398
Pitch = 0.126628
PitchMin = -0.04 <<<<<<<<<<<<&l t;<<<<<<<<<<<
PitchMax = 0.09 <<<<<<<<<<<<&l t;<<<<<<<<<<<
Cqq = 0.01
DragLateral = 0.45
Engine = ~Aircraft/Engine/
PitchControl = ~Aircraft/ServoPitch/MechLink
cd ../
cd Engine/
X = tmvector4r( 1.0000, 0.0000, 0.0000, 0 )
Y = tmvector4r( 0.0000, 1.0000, 0.0000, 0 )
Z = tmvector4r( 0.0000, 0.0000, 1.0000, 0 )
R = tmvector4r( 0.0727, 0.0000 , -0.0109, 1 )
Geometry( "~Geometry/Engine/" )
Mass = 0.064
RangeMassMax = 0
RangeMassMin = 0
Inertia = { 0.0000, 0.0000, -0.0001, 0.0000, 0.0000, 0.0002, 0.0000, 0.0000, -0.0001, 0.0000, 0.0002, 0.0000, 0.0000, 0.0000, 0.0000, 0.0340 }
Kn = 4000
Dn = 10
Dv = 5
cd ServoThrottle/
SignalIn = ~Aircraft/Receiver/Out(20)
P0 = 0
P1 = 1
P2 = 0
P3 = 0
PFirst = 0
Vmax = 50
R = tmvector4r( 0.0000, 0.0000, 0.0000, 1 )
Mass = 0
RangeMassMax = 0
RangeMassMin = 0
Inertia = { 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000 }
Kn = 1000
Dn = 20
Dv = 5
cd ../
cd ServoPitch/
SignalIn = ~Aircraft/Receiver/Out(0)
P0 = 0
P1 = 1
P2 = 0
P3 = 0
PFirst = 0
Vmax = 50<<<<<<<<<<<<&l t;<<<<<<<<<<<< <<<<<<<<<<<<&l t;<<<<<<<<<<<
Mass = 0
RangeMassMax = 0
RangeMassMin = 0
Kn = 1000
Dn = 20
Dv = 5
cd ../
