RE: Engine Mount Screws Wont Budge..
Try taking them out by heating up the area with a hair drier, if no luck run the engine to make them real hot and try again, if not are you trying to remove the engine because you can undo the engine from the top or remove the mounts and the engine as a whole from under the chassis.
