I just bought my first engine for conversion today at harbor freight for $50.00
I need to know what you guys think about the Seagull Laser 200. I can get one really cheap at a shop that is closing. Here are some pics of the weedy & the specs of the plane.
Laser 200 120 ARF Specs
Wing Span: 68.75 in (175cm)
Overall Length: 63.4 in (161cm)
Wing Area: 735.6 sq in (47.4 sq dm)
Flying Weight: 10-11 lb (4.5-5kg)
Engine Size: .90-1.20 2-stroke or 1.20-1.50 4-stroke
Radio: 4 channel
Servos: 6
Trim Scheme Colors: Ultracote Yellow
CG (center of gravity): 1.5" (37mm) behind leading edge measured at wing tip
Prop Size: 15x8 or 16x8 with 1.20 4-stroke
Spinner Size: 3"
Hardware Included: Yes
Flaps: No
Retracts: No
Control Throw (Ailerons): Low Rate - 3/16" up/down or High Rate - 3/8" up/down
Control Throw (Elevator): Low Rate - 3/8" up/down or High Rate - 7/8" up/down
Control Throw (Rudder): Low Rate - 3/4" right/left or High Rate - 1-1/4" right/left
Scale: 1/4
Approx. Assembly Time: 20-30 hours
