Lateral Balance
Hello, everyone, I have a question in regards to the lateral balancing. What I trying to balance is a small electric high wing. The one post I just read said to turn the plane upside down, does it really matter if it's right side up, or upside down? also I have tried both methods, but I must be doing something wrong, sometimes it will lean to the left, other times it leans to the right. I am only using my fingers as balancing points, but I cant get a conclusive answer this way. the battery pack is loaded in the airplane. also if someone can help here, the instructions that came with the airplane don't even mention center of gravity, should I just assume that it's balanced from the factory. This is an rtf, all I really had to do was attach the main wing and landing gear, and charge the battery pack.
