RCU Forums - View Single Post - Lateral Balance
Old 02-19-2006 | 05:28 PM
gjeffers's Avatar
gjeffers
Default RE: Lateral Balance
4005 , this is the same plane i used to learn on and you do not have to do anything except charge the battery and go fly, have you had any experience at flying? if not the only advice i can give you is dont overreact when you throw the plane and it starts to drop right off the bat, just give a small amount of up elevator and it will rise slow, that is what you want, sloww and small movements on the stick,this is a strong little plane , just put a little scotch tape over the battery hatch or the battery will fall out on landing, fold the ends of the tape so you can easily peel it back when you want to remove the battery
good luck[8D]
