RE: computer Power supply
hmmm...
Curious about the 10amp requirement.
I have an old Dell PC power supply that is labeled 4.5 amp on the +12v output and I have another flatscreen power supply that says 4amp. I run one or the other with two chargers as follows:
I am able to run my Hobbico Fast Field Charger MKII with both outputs set at 1 amp and my Sirius Pro Plus running both outputs for both a 900mah RX pack and the OEM TX pack in a Futaba 9CAP transmitter. If the input to the Pro Plus drops below the required level for either the TX or RX a red light will come on...it never has.
Why does he need a minimum 10amps?
JLK
