hanger 9 cap 80"
the assembly was fast ,with only one miner problem with the wing and horizen solved that by sending me another wing it didn't have any backing on one side for the ail hinge to glue to,I also used heavy duty dubro instead of the ca hinges,i moved the throttle servo cause i thoght it might be to close to the engine and it was hard to get to with the fuel tank seting on cg.The engine was new it was the first flight so i didnt do any adjusting and tack readings i will leave it a little rich for a while.The cowl mounting seemed a little odd at first but as it turned out it worked very well.The paint looked real good and matches.
