RE: float set-up and wing incidence
Jerry,
As far as I know, the 2-3 degrees are correct but the reference point is the datum or thrust line of the airplane. 2-3 degrees off the datum line gives the floats a slight downward angle from the fuselage/datum line. The datum line is an extension of the crank shaft of the engine.
