RE: First crash :-(
I'm also suspicious of one broken aileron hinge causing a devastating crash like this one. I've flown a pylon racer with one broken aileron and landed sucessfully. Is it possible you took off too soon and stalled it? Since you're suspicious of your CA installing technique, here's a tried and proven method I use:
CA Hinge Installation
There are several rules to follow for an easy, correct CA hinge installation. These rules are good for hinges from different manufacturers, including Great Planes and Radio South. I’ve used them on many planes from pylon racers to Unlimited class Fun Fly planes to even a giant scale Stinger (the 1/4 scale size hinges). I have never seen an in-flight failure using this procedure.
I have seen only two in-flight hinge failures. One failure was from catastrophic flutter, which also destroyed the wing panel. The other was due to doubled hinges and the use of thick CA.
Here we go:
Use a #11 blade to cut the slots.
Cut only once per side/per hinge.
Use only thin CA.
Do not double the hinges.
Do not use “kicker”.
Install after covering.
1. Slot the wood pieces, install the hinges, and mount the control surface. Gently push the pieces together.
2. Flex the control surface both ways for the maximum amount of travel you expect to use. This will automatically create the proper hinge line gap.
3. Slowly drop 2-3 drops of CA on each hinge at the hinge line on one side only. If any CA puddles in the hinge line, blot it with a paper towel.
4. When that is dry, apply 2-3 drops of CA to the other side of each hinge.
5. When both sides are dry, flex the control surface both ways.
That’s it! The wood will pull out before the hinge will let go. The surface will tend to stay centered and will not flop around. Both will help prevent flutter.
Dr.1
