RCU Forums - View Single Post - balance prop
Thread: balance prop
Old 02-21-2006 | 02:29 AM
Ernie Misner's Avatar
Ernie Misner
Default RE: balance prop
Actually if one side of the prop is slightly heavier, it can be used as engine balance. When mounting the prop, put the heavy side exactly 180 degrees from the piston when the piston is at TDC.
Ernie
