RE: Wrong setting- not enought power
If I read you right you are trying to run this motor on 3S LiPo?
If so you will never get airborne...
I will say you at least need 5S to make the motor work! If you put your batteries in serie, put on a 14x10 prop then things will happend. Still the amperage will be below 30Amp. Propably a 8S setup close to 40 Amp will be the most efficient for the motor...
