RCU Forums - View Single Post - glow starter....what's the best method.
Old 02-21-2006 | 07:18 AM
Mode One
Default RE: glow starter....what's the best method.
Do some of you really think that your way is "THE BEST"? If a power panel is "THE BEST", then why are some of us still using a Ni-starter type glow plug igniter? If Ni-starters are "THE BEST", then why are some of you still using power panels.
Does everything in this hobby have to be some type of contest? The best airplanes are (fill in the blank)! (Blank) engines are the best engines! My (JR, Futaba, HiTec, Airtronics or other) radio is the best!
I'm not saying my way is the best, it's only the way I do somethings and I may even use multiple ways of doing them. In the end, your way of doing something may truly be the best; however, it likely is only the best way for you!
Not trying to cause a "Ruckus"; but, Like they say; "Think outside the box"!
