Question on Roo Engine Thrust Line
Countryboy,
The stock mount is set at 0 deg to the wing but with the high thrust line on the roo most of us set the engine with a degree or two of down thrust by shimming the rear of the engine. By lowering the thrust line you should not need any down thrust and I would assume that 0 deg would be the proper setting.
Todd
