RCU Forums - View Single Post - Pull Pull cables exposed???
Old 12-02-2002 | 06:38 PM
P-51B's Avatar
P-51B
Default Re: Pull Pull ? ? ?? ? ? ? ?
Originally posted by Davie
I have 12" of cable out side on my 3D modified Kyosho Majestics X2 of them. Power is )S 70 four strokes and there is no problem with having that ammount of cable out side of the fuselage. I have flown both of them for 12 months each weekend buring at least 1 to 1.5 gallons of fuel each time I go out for the day.
My question to you would be, " what would be the difference if there was a lot of cable outside of the airframe? Afterall there is at least 22" of cable on the inside > ? ? ? ?? ? ?
As long as you have the cables tight as with any pull pull system, then there is never going to be a problem.
As a point of fact, on my 37% Aeroworks Extra there is a whopping 26" of cable on the outside !!!!!!!
Have a good time with the Flip
Cheers for now,
I believe he is worried about flutter due to vibration of the cables from the airflow around them. This would not affect the 22" inside the airframe...unless there is a hole somewhere.
