RCU Forums - View Single Post - Is this a good setup?
Old 02-21-2006 | 10:04 PM
Nitrofever3D's Avatar
Nitrofever3D
Default RE: Is this a good setup?
S9254
SPECS: Speed: 0.06 sec/60 deg @ 4.8V
Torque: 47.2 oz-in @ 4.8V
Length: 1.6" (41mm)
Width: .8" (20mm)
Height: 1.4" (36mm)
Weigth: 1.7 oz (49g)
Power Supply: 4.8V (Futaba does NOT recommend using 6V)
s9650
SPECS: Length: 43mm between centers of side mounting holes
35.5mm servo body length
42.5mm between the centers of standard mounting holes
Width: 15mm
Height: 28.6mm
Weight: 0.9oz (26g)
SPEED: .14 sec/60degrees @ 4.8V
.11 sec/60degrees @ 6.0V
TORQUE: 3.6 kg-cm @ 4.8V (50 oz-in @ 4.8V)
4.5 kg-cm @ 6.0V (62.5 oz-in @ 6.0V)
[sm=confused.gif] im lost now
