RCU Forums - View Single Post - settings problems?
Old 02-22-2006 | 08:28 AM
pe reivers
Default RE: settings problems?
It depends,
if the situation improves with the needle more open, it was lean, and vice versa.
Just move the needle, and find the best rpm. Then open a bit more so you are sure the engine will not be running lean. That will be the most powerful setting, and the rpm you get will be what you get.
