RCU Forums - View Single Post - Servo resolution with 3D rates?
Old 12-02-2002 | 05:57 PM
WwpIII
Default Servo resolution with 3D rates?
in what way are you putting in "1 step" to see this difference.....if it is using the trim tabs on the transmitter then depending on which transmitter you are using it could be up to 6-10 steps per click...i am flying with the JR 8103 and the "trim steps" are programmable....i find it hard to notice each "step" by only going off stick movement...
