RCU Forums - View Single Post - Servo resolution with 3D rates?
Old 12-02-2002 | 11:51 PM
Joe B.
Default Servo resolution with 3D rates?
No, I am dialing elevator with the stick. I have the mechanical linkages set so that at full servo deflection I get approximately 30° of movement (this is on my elevator). I can move the elevator stick ever-so-slolwly and see each 'step' of the elevator. Some servos worse than others (GWS servos were probably 3° per step!). This was worthless as there was no 'center' by which to go by. As far as the digital trims, yes, they are set right now to 4-steps but to be honest when I click it one step at a time I can not see movement on all steps. maybe every 3 clicks it will deflect a little. I have tried this on my Airtronics and Futaba radios. Currently, its a Futaba 9C with a R148DF receiver (PPM).
Perhaps I need to use PCM to get the 1024 steps? I have 605BB's installed now and they aren't as bad as some others but if I try to crank them to get 45° or more then the steps become more noticable. Definately not 512-steps per side, more like 40 steps or so.
- Joe
