Engine thrust angle etc for Hobbico Avistar
Hi!
1. We left ours just as it came ... no thrust angles added (I think the firewall doesn't have it built in)
2. Several Hobbico planes come with that setup. I don't know of anybody that has ever had problems with it... just make sure you tighten well all the screws. It's OK for the metal-bars to "bend" a little ...
3. We used an OS 46 FX-H in ours and the plane came out pretty nose-heavy ... We didn't really care though, since the plane was a trainer!
...As you can see, we didn't do much except for putting it all together ... the plane flew pretty well and if I had to build another one, I would still avoid things like balancing (as long as the plane is a little nose-heavy) and right-thrust!
