RCU Forums - View Single Post - Engine sync too far apart
Old 12-06-2002 | 09:11 PM
William Robison
Default Engine sync too far apart
George, total absense of perspiration - I've done a lot worse.
Homebrewer, disagree. If the engines are used in a marginally dusty environment you can grind the pistons away in a pretty short time. You will note Edwin is in central Texas. Dusty air is a way of life. That's why I suggested the intake filters.
Regards piston refit: I've used the pipe cutter trick, never found it lasted too long. The whack with a punch is a new one. I have heard of "Cooking" the piston to make it "Grow," don't know how hot or how long. Seems I've seen it in one forum or another, but don't remember where. I have always replaced them when the rest of the engine was still good. AND, I prefer ringed engines except for flat out speed.
Whether new or rebuilt, make your twin go full tilt.
Bill.
