Ok after 3 days of ownership of a new Duratrax Evader I have to say this ST is a POS, being the first RC car in my house I have nothing to compare it too but if this is what the industry is putting out they should be SHOT! First the transmission support, then shock towers, then shock ends, then the steering servo[:@] Now I had a burned out HiTec servo from my boat and took the gears aout and swapped them for the damged ones and for whatever reason the servo will not re center, and if you bump the tires into anything it gets out of whack and you need to trim to get the wheels straight, also how does anyone get the servo saver adjusted right ??? Frustrated I guess, I don't mind wrenching on stuff but when you wrench more than run it is no fun. I can only hope my FG ST will be much better in the reliability dept
