RCU Forums - View Single Post - Tiger Paint
Thread: Tiger Paint
Old 02-22-2006 | 07:43 PM
  #56
Rumnhammer
Default RE: Tiger Paint
Stang I looked at the wires for you. starting from the fat red wire, the fat red wire on the end goes to the positive side of the turret traverse motor, the next one fat white goes to the negative side of the traverse motor the first black wire after that goes to the bottom of the square wire connector up into the turret the second black goes to the top connection of the square wire connection This one has the red wire that goes up to the positive side of the airsoft gun on the other side of the square connector. the next wire is white it goes to the middle connection on the square wire connector, then a thin black wire goes to the front headlight negative and the thin red wire goes to the positive led head light, thats it. should get it together again for you.
Chris
