RE: E-FLIGHT BLADE CP
So, what happens if you try to pull 20 amps from a 7C 1320mah lipo? Is that another way to cause it to explode? I also understand here that if you overdischarge a lipo, that could cause it to explode. Has this happened to anyone? Overdischarging you lipo in flight and causing your heli or plane to ignite into a fireball?
