RCU Forums - View Single Post - Smoke system setup
Old 02-23-2006 | 04:04 PM
OnTheEdge
Default RE: Smoke system setup
I don't have a picture of it at the moment, but two Dubro 40oz tanks on their side will fit between the two motor box sides perfectly. To do this you need to carve a slight relief in the foam on the hatch to give a little more clearance as the tanks on their side slightly project above the motor box sides. If this doesn't make sense, I can snap some pictures for you if you'd like.
.......Mark
