RCU Forums - View Single Post - Foam Wings
Thread: Foam Wings
Old 02-23-2006 | 09:57 PM
Tony Hallo
Default RE: Foam Wings
Finshed cores trial fit together. Time to install the wing tube sockets.
The sockets are fitted with 1/8" lite ply stops to prevent the tube from entering the foam. The socket is supported on the outer end with 1/8" lite ply plate glued into the access hole. The inner portion of the socket is supported by the root plate, I used aircraft ply since a tab will be located on the bottom of the wing to retain the stabilizer. The filler pieces are sanded down and fit in, everthing is glued with Probond poly glue.
ID:	414386   Click image for larger version
